Just bought a F700BT
By sisco22 · Feb 15, 2013in General💬 12 posts👁️ 3,555 views
Posted Feb 15, 2013 · 21:45 UTC#1
Hi everyone,
I just bought a F700BT and am trying to figure out a few things. I want to update the maps on them, but not sure how to do it. The response time on the unit is kinda slow. Is there a fix for this? I haven't messed with any DVD units at all, so I am totally new to this. Can anyone point me in the right direction?
I've looked at a few threads and they are kinda confusing, so I'm hoping someone might be able to guide me on this. I do have the parking brake mod in place.
Any help would be much appreciated!
Thanks in advance!
Posted Feb 20, 2013 · 17:51 UTC#3
Thanks for the reply w4rh4wk.
Here is the firmware version I have:
Version: 2.008000
Map: 01.000600
Posted Feb 21, 2013 · 02:34 UTC#4
ah ok your still on firmware 2.x, when i had my 700 with the 2.x firmware it was constantly reboot and it was slower. you need the 3.x firmware the question is it still available on here. My laptop is just about out of power. I'll see if i can find some links tomorrow.
Posted Feb 21, 2013 · 12:37 UTC#5
Thanks. I found a version called hybrid 4.001 with no maps on the net. Would that be safe to upgrade too? Or should I go with the 3.x? Let me know if you find it. I definitely want to upgrade the maps. These that I have suck lol.
Thanks again!
Posted Feb 21, 2013 · 15:30 UTC#6
uuhh in not sure if you can just skip over 3 ... i wouldnt just to be safe. yours uses the same software as the F700,F900,X710,X910 theres a couple more that i know im missing. X920 software and higher wont work on the F700
Posted Feb 21, 2013 · 15:36 UTC#7
ok, i won't do that then. i'll update to 3.x. were you able to find it by chance?
Posted Feb 21, 2013 · 21:43 UTC#9
I've got it downloaded and on a SD card. Going to try it in a little bit and I'll let ya know what happens. Thanks for the help!
Posted Feb 24, 2013 · 05:29 UTC#10
You can skip over it, but you need to do a wince upgrade and an internal flash storage format. Make sure you backup everything first!
Once you install firmware 4 you can download a torrent called "iGO US Canada Navteq 2011 Q4 (2012)". It should all fit on the flash memory. Telatlas/tomtom map data for igo will work too but the file sizes are too large so you will have to remove states you aren't planning to visit.
Posted Mar 06, 2013 · 15:44 UTC#11
Thanks guys,
I've got version 3.x loaded on there now and it is working good. Alot quicker than version 2. Sorry for the delay in responding. I might look into upgrading to 4, but I'll stick with 3 for now. Thanks for all the help!
Posted Mar 21, 2013 · 15:50 UTC#12
Definitely one of the biggest downfalls on this stereo was the start up time (without the update that is).
