appradio and back camera problems
By rastrello37 · Feb 20, 2013in AppRadio, AppRadio 2, AppRadio 3💬 10 posts👁️ 1,734 views
Posted Feb 20, 2013 · 17:46 UTC#1
Hi,
I have buy appradio SPH-DA02 last week, i have installed on my car, and everything ok until yesterday.
i haven't a back camera installed on my car, I set up for error  ,normal camera, in menu camera setting.
And now i have black screen on appradio whit this message : the displayed image is mirrored.
I try to restart radio,  i have reset radio, i have detach the battery of car, but nothing..
appradio starting normal and just before appear home screen, appradio switch to black screen whit the message  "the displayed image is mirrored", and not it's possible return to the home screen, touch monitor no response, home button no response, i try to connect iphone, nothing response.
i disconnected appradio from my car. :(
how can i restore the default settings?
thank you for the answer and sorry for my bad english
Posted Feb 20, 2013 · 19:24 UTC#2
Check the reverse wire going to the app radio. It sounds like the reverse wire is getting 12 volts making the appradio think the car is in reverse.
Posted Feb 20, 2013 · 20:34 UTC#3
I have to connect the reverse wire? pink cable? i don't know where connect..
Posted Feb 20, 2013 · 22:12 UTC#4
the pink cable is disconnected.. if you haven't back camera but you set in camera options "camera reverse" setting, appradio is blocked on camera screen and is not possible exit from back camera mode.. i think that this is a big bug of appradio!
Posted Feb 21, 2013 · 01:07 UTC#5
i had exactly the same about a week ago, tried absolutely everything.
to get it back to factory, i turned off ignition, and got a paper clip and pressed the little reset button about 5 times..this sorted it
Posted Feb 21, 2013 · 12:27 UTC#6
Thank you very much Mark!! you have solved my problem!! :-P :-P :mrgreen:8)  Great!! i have press 10 times reset button and appradio is back to default factory settings! thank you!
and now i have a new mission.. bypass handbrake.. i have read and it's not simple.. but this is another story..  Bye!
Posted Feb 21, 2013 · 12:38 UTC#7
If you're not from the U.S., it's very simple.  Just connect the green parking brake wire from the appradio straight to ground and you're done.
Posted Feb 21, 2013 · 14:15 UTC#8
Hi texbuck, i'm from italy.. i have a strange green wire..  i have a red clip it's the same wire.. how can simulate handbrake on? In picture handbrake wire open and closed in detail
Posted Feb 22, 2013 · 11:01 UTC#9
That's the wire I'm talking about.  Just attach it to a ground source (you can cut off the clip to attach directly) and you're done.
Posted Feb 22, 2013 · 20:39 UTC#10
Yes! Works! simple! thank you very much texbuck! :-D
