z130BT noise floor audible with internal amp ?
By JohnK · Feb 21, 2013in Problems/Troubleshooting💬 4 posts👁️ 645 views
Posted Feb 21, 2013 · 00:42 UTC#1
I have a z130BT installed in my car and for now am using the stock internal 18wx4 amplifier.
When I play SD or USB source (and I'm pretty sure DVD too) and have the volume up in the 17-18 range I can start to hear a noise floor.  It's pretty low but is still discernable when the source material is completely silent or during the "mute" moment while changing tracks.  The specs say S/N ratio is 79db which isn't great.
But before I go out and buy an amp to use the pre-outs, I'd like to confirm this that the noise floor I am hearing from the internal amp is normal.
Thanks.  John
Posted Feb 21, 2013 · 16:12 UTC#2
does your car have in inline amp?
according to the owners manual, the amp s/n ratio should be much better:
Power output ............................. 14 W RMS × 4 Channels (4 W and ≦ 1 % THD+N)
S/N ratio ....................................... 91 dBA (reference: 1 W into 4W)
Posted Feb 24, 2013 · 16:22 UTC#3
No inline amp that I know of.  I still have to get the radio antenna amps connected though ... maybe that has an effect on it?
I see the 91dBa spec -- don't know where I got the 79 from ... I must have spaced and been reading the wrong PDF file (although I downloaded the z130 specifically ... hmmm).
I'll check individual speaker outputs to see if there is a difference.  Eventually I plan to install an external amp so if I can't solve this minor annoyance sooner then it will be solved later.
But those of you who are using the internal amp on this unit hear no noise floor at vol.20 ?
Thanks.  John
Posted Mar 05, 2013 · 19:49 UTC#4
(moved to new thread)
Edited Mar 05, 2013 by JohnK
