Noise after Connecting iPod in appradio 2
By JLs64 · Mar 13, 2013in AppRadio, AppRadio 2, AppRadio 3💬 4 posts👁️ 1,674 views
Posted Mar 13, 2013 · 07:00 UTC#1
Hi,
I have recently noticed that there is noise when i connect my iPod and it is a constant noise and does not increase or decrease when I change the volume  and when I diconnect the ipod, the noise will go away! Does anyone have a similar experience?
(I use KTP445U to amplify the signal a little bit.)
Posted Mar 13, 2013 · 09:34 UTC#2
You have a ground loop. Your Alpine may be causing it. Do some research to see if other users of the KTP445U have had similar issues.
Posted Mar 14, 2013 · 06:59 UTC#3
Thanks Dannzy, I connect the ground of the radio to the chasis and the noise is gone, i guess it was the problem with the ground wire that I used from the harness.
Posted Mar 14, 2013 · 10:41 UTC#4
Glad I could help.
