iphone 5 x940bt appradio extensions
By xrevolutionx · Mar 13, 2013in Hacks/Mods💬 7 posts👁️ 5,074 views
Posted Mar 13, 2013 · 21:48 UTC#1
Hello all,
I have read about nine forums and am only looking for an answer to wether the appradio extensions will allow my iphone 5 to appear on my x930bt upgraded to x940bt software. I know i might need the lightening to vga and the pionneers vga to the deck adapters. Before I buy all that junk does anyone know wether this even works?
Thanks for your time
Joe
Posted Mar 15, 2013 · 19:04 UTC#3
To my knowledge the 930 does not have the connection to support the VGA adapter so the answer is no. You will need to consider a new unit. Any unit that has the ability to accept the U220 or the new U250 add on navi units ( AVH Units) will work with the VGA adapter.
Posted Mar 15, 2013 · 19:08 UTC#4
If you are going to consider a new unit and don't need the CD/DVD slot I recommend the App Radio 2. They're going for a little over 300 bucks right now on Amazon and 279.99 at Crutchfield after a 120 dollar mail in rebate.
Posted Mar 15, 2013 · 19:29 UTC#5
Vblue42,
thanks for your time. I was under the impression that the 930 and 940 for the most part where the same except software?
That http://www.pioneerelectronics.com/PUSA/Car/Accessories/iPod-and-iPhone-Cables/CD-IV202NAVI would plug into the back of the 930 like it does the 940. I guess after looking around, the cable is not yet available. I was hoping this cable might do the trick? what do you think?
Thanks again for reaching out.
Joe
Posted Mar 15, 2013 · 23:15 UTC#6
That cable will not interface with any navi unit prior to 2013. An example of the port it plugs into can be found on any of the new AVH units. This port is not present on your unit or any navi unit prior to 2013.
