I have a 2008 Chevy Avalanche and I just installed the AVIC X930BT using the Axxess gmos-lan-02 harness as well as the ASWC. I also did the video bypass while I was wiring everything else. After the install, no sound comes through the speakers unless I have the turn signal or hazards on. If I have them on, the radio or CD plays just fine for as long as I have the blinker on. So I know my speakers are wired correctly and able to produce sound, OEM sounds work correctly, Bluetooth works fine (although no sound without blinkers), and NAV works fine. Steering wheel controls also work fine (took awhile to recognize the Pioneer, but I finally got it to work fine).
What is going on? I tried bypassing using a relay and not just grounding the mute and parking brake wire, but that didn't seem to change anything going on with my problem. I've also tested all my grounds multiple times and they are all good (I even took an extra wire to the car chassis). Please help! Thanks!!
