Felt that with the range of confusion and misinformation about this topic one of these would be handy. Let me know if I get anything wrong and what I'm missing and I will add and change this to reflect it.
Q: What do I need to get started?
A: You will need an Appradio 2 running version 8.30 of their software, an iPhone 5, a lightning AV adaptor, an hdmi cable, and a lightning cable.
Q: why can't I just use a lightning to 30 pin connector to use my appradio 2?
A: the lightning to 30 pin connector does not provide a video output necessary for appradio apps to work. It only provides USB data, power, and analog audio out.
Q: Do I need the pioneer cable to use my iPhone 5?
A: No. The pioneer cable is just a simplified version of the cable that already comes with the appradio 2 and an hdmi cable. Plugging your lightning cable into the USB port of the iPhone cable that comes with your radio and using your own hdmi cable will produce the exact same results.
Q: Why doesn't pioneer update my appradio 1 to work with my iPhone 5?
A: Because they can't. The appradio 1 has a simpler Bluetooth system that is not designed to control the phone in the way the appradio system needs. With the appradio 2 pioneer already set the system up to control phones via Bluetooth for android devices while using hdmi for video and audio. The iPhone uses a modified version of this system.
Q: why does it need Bluetooth to control my phone?
A: because the lightning AV adaptor does not provide the appradio 2 with a usb data connection. The lightning port on the AV adaptor is solely for power.
Q: How long does it take to connect via Bluetooth?
A: About 30 seconds.
Q: Why is pandora so slow now?
A: unlike all other appradio apps, pandora is run from the radio's hardware and not mirrored by the phone. The built in app normally gets the data you see via the USB data connection. On the 5 that is not possible. It instead gets the data it needs from Bluetooth. Bluetooth is far slower of a a data transfer system than USB 2.0 so it slows the system down downloading the necessary data to run.
Q: why don't some of my apps work anymore?
A: apps need to be updated to support iOS 6.1 and the iPhone 5 to work with appradio. Until your app is updated it will not work. Check the pioneer website for a list of supported iphone 5 applications.
Q: Why is the iPod app broken?
A: for the same reason pandora is slow now. The iPod app needs the USB data connection that the
Lightning AV adaptor does not provide. Use carmediaplayer to control you iPod music on the appradio. Unlike pandora the iPod app does not support control and metadata via Bluetooth.
Q: can I mirror my display?
A: Yes. You need a parking break bypass.
Q: Can I control my non appradio apps with appradio?
A: not yet. Check the betas for appradio extensions. It may be possible in the future.
http://avic411.com/index.php?/topic/34188-appradio-extensions-20-beta-full-iphone-control/
