cntrylvr79 said:
GreatRock said:
CTS 2005,
If I connect ILL wire To parking light wire What about Z1's Parking wire? Is that gounded?
The z1's parking brake wire I'm guessing gets grounded for the bypass to work. Not sure really. As for the illumination wire, looks like the car doesn't even have a parking light wire that would work. God I hate gm gottta make life difficult.
If you have a working ILL wire, then the parking brake wire SHOULD NOT be grounded. It shouldn't be connected to anything if possible (if you plan on something or you flashing your lights). And there has to be some wire somewhere that will work as an ILL line. It wants to see 12V when the lights are on and nothing when the lights are off. They might not have run the wire up to the radio, but I would assume they did, since the stock radio dimmed with the lights on right? Then there is something in the dash, but if not, you might have to run a wire to the headlight switch or to the lights or something, but somewhere in that car, some wire gets energized to 12V when the parking lights are on. I might be a pain to find it. And I'm sorry if it is. You sure there is nothing in the radio connector? It might not be on the Metra adapter or whatever, but it might be in something the oem harness that's not brought out with the harness.
