Z110 no longer knows when vehicle is stopped- cannot access 'system settings', the icons are grey and not able to open
By MojaveSTi08 · Mar 22, 2013in Problems/Troubleshooting💬 4 posts👁️ 1,404 views
Posted Mar 22, 2013 · 03:43 UTC#1
I recently replaced my STi battery and since then my z110 no longer recognizes when the car is no longer in motion, therefore not allowing me to open many settings options such as system settings, Bluetooth settings, etc... The icons are present but are greyed-out as if the car was in motion. I recently upgraded to an iPhone 5 and need to sync it's Bluetooth hands-free to the AVIC... I can also no longer type in an 'address' for navigation, my only options I can select that aren't greyed-out are the 'History' and 'Return Home' icons.
I have not done the bypass hack and faked-out the brake sensor. I have been meaning to but haven't taken the time yet. Think the brake-bypass mod will solve my problem?
Is there anyway to reset the unit without disconnecting the wiring harness?
Has anyone else had this issue?
-Jesse
Posted Mar 22, 2013 · 06:15 UTC#2
You either need to connect the parking/hand brake wire or preform the bypass.
Posted Mar 26, 2013 · 20:39 UTC#3
Right, It is better for you do the bypass, so you can change the setting anytime you want!
Posted Apr 03, 2013 · 23:08 UTC#4
Did the bypass and all systems are a go. Thanks!
