So we all know that Yellow is constant 12v and red is switched 12v.
Which one is actually expected to supply power to the unit for the internal speaker amp?
- I have seen some radios claim that the primary power comes from the constant 12v, and the switched 12v is only used as a signal wire to tell the radio to turn on. Much as the 12v illumination wire would signal dimming of the display.
- I have also seen some radios that claim that the constant 12v source is used for memory backup only, and the switched 12v carries the power to operate the radio.
I have installed the z130bt in my 2005 Mercedes C230 (W203 chassis). This car has no switched 12v wire in the harness, forcing me to tap into the cigarette lighter for that switched power source. The car uses a CAN-BUS digital communication protocol, which transmits, among other things, ignition status of the car. So I have to believe that the car's stock radio expects it's power to come from the constant 12v source, and ignition status comes in through the digital bus. The constant 12v source is rated 10A on this car.
Since the Avic needs a hardwire switched 12v, the common way to hook these up in the mercedes is to tap into the cigarette lighter power. The cig lighter fuse is rated 15A, and since I don't use it as a lighter I have the full 15A available to power the radio if needed.
My son's Honda Accord has both constant and switched 12v in the car's harness, but the fuse ratings are 10A for constant 12v and 15A for the switched 12v. I believe the switched wire is rated higher because it is shared with the cig lighter ... but the side effect of that is that regardlesss of which wire an aftermarket radio expects to supply power, in the Honda it will get 10A minumum either way.
So, my question is, which wire is expected to power the Pioneer head units, and specifically their internal amps? And, what is the required fuse rating? Is it only 10A, which seems to be what cars have listed for their radio fuses?
Thanks. John
