will appradio 2 give my ipod GPS? I just wanted to know so i can have my iphone in my pocket and use it for bluetooth calling only and use the ipod for appradio function.
Will this work (If so, great, i'll have to buy an ipod)
Yes it will but which iPhone and which iTouch do you have?
iphone 4 and ipod touch 4
You should have no issues as long as your devices are on iOS 5.11 or less.
should i also update my appradio to 8.17?
edit - also why would it be a problem if i have ios 6? i am currently on 6.0.1
iOS 6 does not support the External GPS input to the iPod!!! There is a bug that has been created by the iOS 6 that prevents the iPod to receive external GPS signal. Some people said that it has been fixed in iOS 6.1 but came back in the later updates!! Seems like Apple does not care about the External GPS connectivity.
However, there is a fix for that but it is temporarily and will come back after your iPod has been disconnected from the appradio for a while...
That will do it! At least that does work for me until Apple decides to fix that bug which is annoying!
If that is convenient, go ahead and buy iPod but I would recommend you to stay away from iPod if your main reason for purchasing it is to use GPS apps.
i am using my appradio 2 with an ipod 4th generation and it works very well with iOS 5.1
questions -
1 - is there any issue with my iphone 4s being on ios 6? (i havent installed the appradio yet to try)
2 - if i do find an ipod touch wit ios 5.1.1 how would my GPS work if the maps isnt stored in apple maps and google maps? (just thought about that a minute ago) the only maps i know that has maps stored in the harddrive is tomtom.
3 - will tom tom and garmin work too?
2. Most GPS apps have onboard maps but you would need to tether your iPod to your iPhone. Jailbreak both devices and have no worries.
3. Neither are AR compatible. iGo Primo is and is far superior in my opinion. Also look up the thread dealing with AppRadio Extensions in reference to unsupported apps.
thanks. im going to have to jailbreak and give the sticky a good read!
i'm sorry but i will believe when someone will show a video prove that on "live"
