How do shops run rear camera wire in Dodge pickups?
By grindle_speck · Mar 28, 2013in Vehicle Specific Wiring💬 2 posts👁️ 2,421 views
Posted Mar 28, 2013 · 07:04 UTC#1
I have a 2006 ram and I just installed a 140, I dont have the camera yet, but looking at the truck I dont see a good way to get a camera wire into the cab. How do the install shops run theirs??
Posted Apr 04, 2013 · 16:42 UTC#2
Assuming you have an automatic transmission, there should be a plate covering where the clutch linkage passes through the fire wall on a manual transmission truck.  You can remove this plate and drill it for a grommet.  I installed mine before I knew about that plate, I put a slit in the boot for my factory harness and passed the wires through there.
Look on page 3 of this pdf:
http://www.genosgarage.com/installation_instructions/GGInstall-DG-GaugeInstallTips03-09.pdf
Here is how I mounted my camera in the tailgate handle:
http://www.dieseltruckresource.com/dev/showpost.php?p=2798380&postcount=8
Edited Apr 04, 2013 by BroncoAZ
