Title says it all. How does it work. I have an avh 5500 and want to make my own bypass
How does the micro bypass work?
It is basically a NO or normally open switch, power comes on, it waits a bit, the switch closes then re-opens. That is the regular micro bypass, the AVH 8400 requires a double pulse so same thing - power on, wait a bit, switch closes, switch opens, switch closes, switch opens. Not sure if the 5500 needs the single or double pulse. Also, I have a 4400 which needed a single pulse bypass but then I installed the separate nav module and it needed a double pulse bypass with the navigation installed.
Does this happen continually the sequence? I wang to make my own.
Ok so it looks like I am able to simulate the bypass with my arduino. Now I just need to finder a cheaper way to make it
i Have a avh-5500bhs and am interested in making my own bypass as well.
Can i just pulse 12 volts or negitive wire to the parking brake wire ?
how exactly does it work ?
Currently I am using a arduino and a transistor. I am powering the arduino from the amp turn on wire from the head unit. I just wrote a simple code to pulse to ground the ground wire. Really easy
I had a 'regular' bypass that I had used for a Sony XAV-602BT that was just a relay. Initially when I got a AVH-8500BHS I used my old bypass and put a switch on it so I could flip it the second time. Ended up installing a Microbypass last week. It's such a small convenient package I couldn't justify building my own.
