Hi all.
New to the AR but pretty technologically capable. I have an odd fault with my DA100 that maybe someone might shed some light on.
Wired and fired up my AR2 before competing dash installation and checked the radio function to get it working. No problem - fired up as it should. Completed installation, installed v8.30 and the FM radio (app; if you like) has not worked since.
Specifically, I get all the lines and boxes in the right place but they are not populated with data. The remote (blue/white) wire triggers, because I hear the handbrake bypass relay close, so the AR knows I have called for radio, but it remains empty of choices and any data - except the time.
Any ideas?
