X850bt GPS won't move
By Layziedakid · Apr 16, 2013in General💬 6 posts👁️ 1,265 views
Posted Apr 16, 2013 · 13:46 UTC#1
I'm new to this forum, just installed the x850bt. Everything works great except the GPS. The map itself is stuck on the location I was when I installed the unit. The arrow and map won't move when I drive. I drove a few miles away then input where I was when I installed the unit to guide me and it just tells me I'm already there.any input would be appreciated. Thanks
Posted Apr 16, 2013 · 16:18 UTC#2
Where did you mount the GPS antenna?
Posted Apr 16, 2013 · 16:27 UTC#3
Right above the radio underneathe the dash. It says that the GPS signal is good.
Posted Apr 16, 2013 · 16:44 UTC#4
I literally just installed my 850bt yesterday, have the GPS antenna under the dash as well. It's probably not as strong as a connection as it would be outside, but it still picks up 5+ satellites. Takes a few minutes longer the first time you hook it up, I think.
Did you mount it on the little metal sticker plate they sent? I have read that helps.
Posted Apr 16, 2013 · 16:49 UTC#5
It's mounted on the sticker that it came with, I think it was picking up 3 satellites.
Posted Apr 16, 2013 · 19:48 UTC#6
The more I use it, the better it seems to get. I reset my GPS settings and now it seems not as accurate, but its still moving. I am having issues with my XM antenna under the dash, I am reading that you are going to want to move them as far up towards the windshield as you can
