Set the gains on my amps today. I used 40 hz test tone for bass and 1000hz test tone for high amp
But I am not using amp that's built in the radio my mids and highs are running off a amp
So I can't tell when the deck signal starts clipping. Anyone here had their system tuned and gains set with a O-scope? What volume did they tell you not to turn deck past
When setting gains eq and bass boost should be off, open up crossover's so amps get full signal
If you use test tones like I did all you have to do is turn up gain till the note changes the back off gain right under that point. It's best to use 0 db test tones. Both 40 and 1000hz are easy to tell when you set gain to high. The 40 will sound like a different note and the 1000 sounds like it ( breaks) or cracks for not finding a better word to explain it on the 1000hz
