First and foremost I will appologize if this topic has already been started (I just haven't stumbled on it yet)...
So I just installed a new X950BH in my 2009 Jetta Sportwagen - the parking brake bypass works as described; one warning and good to go. Although I would add, if you have the extra $10 bucks lying around, spent it on wire with the pin crimped on it from Amazon - you'll save yourself an hours worth of headaches. Anyway -
The issue - I have an iPod Touch with a software version of 5.1.1 on it. It seems to play ok, but I have no control over any of the play lists. That is, I would expect to be able to hit the "music" button at the top and have a menu come up with artists, play lists, favorites, etc... I usually can hit the "video" button, select a video, watch it, then one done, hit the music button and behold the menu that I would have expected. One thing to note, once I pick a playlist, it is now stuck there just as mentioned in the beginning. Also note that when playing a video, I would think that I could also hit the video button and get back to the video playlist menu - can't do that either, same as the music when playing.
Has anyone else seen this? Not being an iPhone guy, does this fall under the lines of the iPhone 5?
Thanks.
Scott
