Can someone explain how to route the antenna wire from the inside under the dash to outside of the vehicle (in my case a 2007 Sequoia) so I can place the Z1 Nav antenna on the roof, center, right above the front windshield?
My understanding is that once the cable is outside, I tuck it under the rubber seal, however, if I do this, won't the windshield leak at the top where the cable exits the rubber gasket/seal?
Thanks for the help!
