Chagne ROM to add more Bluetooth profiles?
By JLs64 · Apr 28, 2013in AppRadio, AppRadio 2, AppRadio 3💬 16 posts👁️ 4,660 views
Posted Apr 28, 2013 · 21:46 UTC#1
Don’t know that is feasible but is there anyway that the Bluetooth profile can be changed in AR2 so it can accept A2DP or other profiles? That is absolutely missed in AR2 and other manufacturers had a while ago on the HU!
Posted Apr 29, 2013 · 00:14 UTC#2
No. However I suspect that when the new App Radio is released (SPH-DA110) which includes A2DP, we may see a unit upgrade that will include that feature.
Edited Apr 29, 2013 by VBLUE42
Posted Apr 29, 2013 · 04:43 UTC#3
Let’s hope for that! Although if you look back to the AR1 and AR2, they did not change the way AR1 was working when they released the AR2 with the android compatibility. But I will hope for that because audio streaming is something I really want to have right now. Thanks VBLUE42.
Posted Apr 29, 2013 · 23:42 UTC#4
AR1 was a completely different unit hardware wise then AR2. The new unit appears to be the same hardware as the current AR2.
Posted Apr 30, 2013 · 02:44 UTC#5
That would be fantastic having the Audio Streaming on my system! Did they announced any date on the launch of the new AR? I hope it is soon tho!
Posted Apr 30, 2013 · 23:26 UTC#7
Thats great!!! Us woulf probably get it around that time as well since AR2 has been release close the release in Euro.
I noticed a quote in the article for DA110 that said: "Parrot Bluetooth allows for hands-free and now wireless audio streaming from a Bluetooth-enabled device."
Does DA100 comes with the same hardware?
Posted Apr 30, 2013 · 23:35 UTC#8
This is unknown.
Posted May 01, 2013 · 02:19 UTC#11
So that means it is exactly the same as DA110 and they should release the firmware for it and in the worse case, there should a fireware hack that can enable the Advance Audio distribution profile! I am so looking forward to the new update now!!! that would make it a great radio!
Edited May 01, 2013 by JLs64
Posted May 01, 2013 · 02:28 UTC#13
I looked today for the very same thing but couldn't find any info.
Posted May 01, 2013 · 02:29 UTC#14
Still too early to tell. Wait for report on DA110 and if V9 update for DA100 bring anything new.
Posted May 01, 2013 · 02:40 UTC#15
It is too soon but if they both uses the same bluetooth module, the both can perform the same way. I found that SPH-DA09 has the same module as the one used in DA110 but I have not seen SPH-DA09 before so i can not be sure that is the same as DA100
Posted May 01, 2013 · 02:47 UTC#16
The 09 appears to be the Japanese version of the 100 so this is promising.
