I may be avictarted but i cant seem to figure out were the SWI-PS plugs into the AVIC. Can someone help me on this one??
Also my Source button on my steering wheel isn't read by the SWI-PS when programming. Any ideas?
Thanks !!!!
Thanks !!!!
Into the wired remote input. I believe its on the RCA pigtail that plugs in but it may be the other one
The swi-ps has a headphone jack type plug in... do i need some sort of converter?
Nope
got it thanks, im a little slow tonight.
I havent installed mine either, so that head phone type jack doesnt get used at all?
Or the wired remote input can take that jack as is?
Thanks, kind of new to the steering wheel adapter thing.
yea there is a wired remote input on connector 1. Its black and accepts the steering wheel controls as is.
I gotcha! Thanks! I have one general question about the PAC SWI, If I disconnect my battery , do I have to reprogram the unit again?
no it has "volatile memory" or some such junk they call it in the manual it should say so you don't have to reprogram
BEST PART
I gotcha! Thanks! I have one general question about the PAC SWI, If I disconnect my battery , do I have to reprogram the unit again?no it has "volatile memory" or some such junk they call it in the manual it should say so you don't have to reprogram
BEST PART
You mean NON volatile memory. Volatile memory is like RAM, lose everything when you disconnect the power.
