ND-BT1
By lowriderman3 · May 29, 2006in Problems/Troubleshooting💬 11 posts👁️ 4,940 views
Posted May 29, 2006 · 03:42 UTC#1
Okay so I finally got the ND-BT1, but I have a slight problem with pairing them to each other. I can get through everything, but then it ask me for the Bluetooth Passkey code. Pioneer book says it is "1111"..I tried this, along with many other numbers/codes, and nothing works. It says "invalid pin".
I reset the deck even. Any ideas on who to reset the pin back to the default? I have never changed it to begin with, so this is weird....Should I just call Pioneer and ask them. They will not be re-popening until Tuesday anyhoo.
Posted May 29, 2006 · 04:34 UTC#2
just go to phone setings and change the pin n"m to any number you want
just press on the password part phone setings delete the defult and enter any password you want
Posted May 29, 2006 · 13:24 UTC#3
^Thanks...I will give that a try this morning.
Posted May 31, 2006 · 01:10 UTC#4
^Good deal..Everything worked out and the unit connected..Thanks!
Posted May 31, 2006 · 21:04 UTC#5
Does anyone elses Z1 display the Bluetooth Unit Connected everytime you start the car...I thought that would just show up the first time after you installed it...
Posted May 31, 2006 · 21:44 UTC#6
yes evrytime you turn the unit on it will show on the screen for few seconds not big dill.
Posted Jun 01, 2006 · 00:36 UTC#7
Yeah, no big deal, just thought it a bit odd.
Posted Apr 26, 2009 · 20:26 UTC#8
Need help pairing ND-BT1 in AVIC-Z1 with Blackberry Storm
When I run the bluetooth from Storm it says device found
DOES not let me enter passcode and fails the connection
Any ideas??
In the past with my Treo I was able to synch first with a bluetooth headset then synch with the Z1
this did not work
Posted Apr 29, 2009 · 22:22 UTC#9
try 0000 as your passcode
Posted Apr 29, 2009 · 22:53 UTC#10
Is there a way to set the Z series to give the option to answer or no... or do all calls just come straight through when you connect the phone to bluetooth?
Posted Apr 29, 2009 · 23:02 UTC#11
sorry, i didnt read your whole post, try to initiate the pairing from the headunit, you ill need to set your Storm to "listen" for a device to find it in the settings menu, then set up connectin, and click listen
