Auto EQ on AVH-5500
By pennengr · May 03, 2013in Pioneer AVH Series💬 7 posts👁️ 2,852 views
Posted May 03, 2013 · 21:54 UTC#1
Hi - I'm having a problem where this setting (auto equalization) is greyed out.  I've tried with the receiver both off an on.  Any ideas?
Thanks,
Win
Posted May 04, 2013 · 01:22 UTC#2
Do you have a bypass?
Posted May 04, 2013 · 01:31 UTC#3
I do. Video's working fine.
Posted May 04, 2013 · 01:46 UTC#4
Auto EQ has been know to not work with a bypass. Ground the p brake wire and see if that changes anything.
Posted May 04, 2013 · 01:56 UTC#5
Hmm. Before I installed the bypass yesterday I had the brake wire straight to ground with the same issue.
Posted May 13, 2013 · 19:35 UTC#6
Do the special mic plugged in?
Posted Jul 31, 2015 · 21:59 UTC#7
I don't know if a 5700BHS is the same, if it is, will temporarily removing bypass from system allow auto EQ setting to be loaded?
