Attempted FX3.1 fix and now I get initialization error: LoadLanguage failed
By angermeans · May 07, 2013in Problems/Troubleshooting💬 3 posts👁️ 2,818 views
Posted May 07, 2013 · 06:23 UTC#1
Hello all,
Any help would be much appreciated. So a couple weeks back my battery died and then a couple days after replacing it my AVIC-700BT stopped loading. I found the FX3.1 fix and got it to work after resetting the WINCE stuff and got it all done. After copying files over to the system I started to get a couple errors which I had to skip.
I then reset the system for 5 seconds and it looks like it is going to load and I get this error:
Initialiazation error: LoadLanguage failed.
Anyone had this issue or know what I could do to fix it?
Posted May 09, 2013 · 08:50 UTC#2
I got the same error because I copied the files to my SD card using a Mac laptop and the .DS_Store files created automatically was causing the problem. I repeated the steps for copying the files to SD card using a windows machine and it was gone.
Posted May 11, 2013 · 20:26 UTC#3
Ahh thank you so much for taking the time to post. I bet that is what is going on. Ive spent hrs upon hrs trying to get this to work. Did you have to redownload the files and then put on SD card or simply just move the whole thing over from the FX3.1 fix?
