pioneer x940bt navigation not working
By trentstout23 · May 07, 2013in General💬 4 posts👁️ 1,417 views
Posted May 07, 2013 · 14:43 UTC#1
just finished installing and everything works except navigation.  i mounted the antenna on the dash.  it shows my location but i cant access the menu to input an address. its installed in 2013 tacoma.  i didnt hook up the pink wire(car speed signal input) or violet/white( reverse gear signal input) wires.  i read on here that everything should work fine without these two wires hooked up.  i cant click on anything nav-related because its not lit up on the screen.
Edited May 08, 2013 by trentstout23
Posted May 21, 2013 · 06:17 UTC#3
if options are greyed out, then it sounds like you have a problem with your bypass.
Posted May 21, 2013 · 06:21 UTC#4
you say that you used that bypass, did you make sure the pin was in the right slot? is that wire grounded, and is the pioneer parking brake wire grounded?
i have a feeling that your problem lies with one of these steps...
