Weird intermittent screen issue SPH-DA02
By piddy · May 10, 2013in AppRadio, AppRadio 2, AppRadio 3💬 12 posts👁️ 2,471 views
Posted May 10, 2013 · 10:44 UTC#1
Hi guys
I've not had my SPH-DA02 long but since I've had it I get an issue every now and then.
When plugging in my iPhone 4 it (sometimes) shows the iPod section and the Apps section with a blur of messed up graphics. I tried to get a photo but of course it needs my phone to create the issue, so I will have to borrow a phone to take the photo. It almost looks like the LCD is broken but the home screen and bluetooth section is fine.
Also I can still play music and use the phone.
It tends to happen in the morning. Almost every morning in fact.
So I thought, perhaps it was temperature related. But it happened yesterday afternoon too.
Any ideas please?  :-D
Edited May 10, 2013 by piddy
Posted May 11, 2013 · 21:27 UTC#2
Bump
Posted May 13, 2013 · 19:10 UTC#3
Please help me :(
Posted May 14, 2013 · 16:42 UTC#4
It sounds like there is a problem with your connection. Check your port on your phone. Especially since you have a 4 I'm guessing you've had it a while. Your port may be filled with gunk. clean it and see if that fixes your issue. If not that then maybe your cable is failing. How long have you had the unit?
Posted May 14, 2013 · 23:32 UTC#5
Thanks for the reply - not had it long and the problem is only occational which is why I didn't think it was that. Will have a fiddle and see if it helps :)
Posted May 15, 2013 · 02:04 UTC#6
Check the whole Cable. It might not be at the iPhone end. The cable may be improperly installed at the headunit.
Posted May 15, 2013 · 14:13 UTC#7
I will do - should be going back into the shop to have some speakers added so i will ask them to check
Posted May 15, 2013 · 14:47 UTC#8
See that's the first mistake. Always do it yourself. When you have someone else put it together you won't know why something could be going wrong when something goes wrong.
Posted May 15, 2013 · 22:00 UTC#9
See that's the first mistake. Always do it yourself. When you have someone else put it together you won't know why something could be going wrong when something wrong.
Danny some people are not capable or just don't want to do the work themselves.
Posted May 15, 2013 · 22:03 UTC#10
Hi guys
I have mine for a month and sometimes the iPod and Apps sections don't "light up" when the cable is connected. No reason why. Cable is good. Connections behind HU were checked. I find that turning off the car and trying again in 15 minutes fixes it but like I said it doesn't do it all the time.
Posted May 16, 2013 · 21:08 UTC#11
I would really cock it up - get a man in is my motto
Posted May 16, 2013 · 21:17 UTC#12
Bad motto if you are a man :mrgreen:
