Broke already!
By germinus · May 12, 2013in AppRadio, AppRadio 2, AppRadio 3💬 8 posts👁️ 1,990 views
Posted May 12, 2013 · 17:52 UTC#1
Well got my appradio 2 installed an hour ago and its broke already! tried to do a firmware update and the unit got stuck just froze, turned engine off which should of turned the power off to the radio but it stayed on for 5 mins and then shut off and now the unit is dead, just a black screen, cant even be sure that power is till geting to it!! Owned it less than 10 mins and broke! Any ideas?
Posted May 12, 2013 · 19:06 UTC#2
reset the the unit. it stays on for 5 minutes because your car has the delay until you open the door
Posted May 12, 2013 · 19:37 UTC#3
How do you reset?? Remember I cant get into settings to do anything as its a blank screen. I have tried everything! And the unit never stayed on when I shut the engine off  the first time. I think the unit is dead cant see any sign of power, even the iphone doesnt make that nose it makes when you first plug it in
Edited May 12, 2013 by germinus
Posted May 12, 2013 · 22:12 UTC#4
So how do you reset when you can't use the unit?
Posted May 12, 2013 · 22:51 UTC#5
Unplug it. But it does sound like it is dead so you will likely need to have it replaced.
Posted May 22, 2013 · 07:55 UTC#6
Make sure the 12Vdc for saved the informations is off to. The unit have two DC power:
-one when you turn on the car.
-one PERMANENT for save your settings.
Posted Jul 09, 2013 · 01:47 UTC#7
Hello Germinus. It was the same case with me, you could solve? I do not know what to do, if anyone can help me ...Sorry my english, i am from Brazil. Thank´s.
Posted Jul 09, 2013 · 02:47 UTC#8
Mine did this a couple times since owning it. Within the first couple of months it had gone black on me. But my Bluetooth was still connected. I would leave it for a few hours and it would come back. Has not done it since last september.
