Hi All,
i received a notification from Pioneer about iPhone 5 update availability (i've an european AVH-8400BT).
As i've got an iPhone 5, i downloaded the ZIP and followed the instructions.
Step 1: BT Firmware -> OK!
Step 2: First file -> OK!
Step 3: Second file...
I put the USB flash drive in, demo appeared, so i pressed menu button. The demo crashed. I had the part about the "MIXTRAX" feature freezed on the screen. I pressed the RESET button on the unit and... booom!
The unit doesn't power up anymore.
Black screen. Completely dead. Nothing!
I checked the fuses and they're ok.
I tried to disconnect the unit and then reconnect it. Nothing.
It's dead.
I'll take it to a repair center tomorrow, but i want to ask you: did you have success updating your 8400bt firmware? Do you know if there's a way to power up the unit and fix this issue?
