***EDIT: PROBLEM FIXED, READ IN QUOTE FOR FIX, ORIGINAL POSTS KEPT FOR FUTURE REFERENCE***
So in case anyone has future issues, Im going to post what fixed mine here.
NUMBER ONE THING, MAKE SURE YOU HAVE A GOOD ***AUTHENTIC*** SD CARD
I know there are lots of replicas, I didn't even know the one I had was one until I used the one in my Samsung phone. The update loaded up and started, currently at the second boot screen as we speak. So please make sure your using a GOOD, AUTHENTIC SD CARD for the update.
My x920bt was a virgin and luckily I somehow backed up PRG0 and PRG1. I just restored those folders and the small PRG file in the USER folder and was able to then boot the update.
What I learned:
***PLEASE BACK UP YOUR USER FOLDER** You can accomplish this with the super testmode.key on a USB. Choose File Maintenance then copy the entire USER folder to your USB.
If you for some reason crash your system/get constant errors/etc. restore the USER folder and make sure your SD card is good and formatted.
To make things short, I was updating my bone stock x920bt to the CNSD-310FM using the "supereasymethod". When it got to 6% it said "Incorrect Card Info, Insert Correct Card". I kept retrying only to get the same error each time, so I downloaded the map pack once more and unzipped it on a Windows using a recommended program.
My x920 was stuck in boot mode so I loaded up test mode and deleted a file recommended by Pionara to kick it out of update mode, which it did.
Now my system loads though seems to be missing files/is lagging and a lot of thigns arent working. So I replaced all ver.info and card.info files on the freshly unpackaged map pack and I cant get it to load the update program.
I also went as far as manually replacing the renwallfib.dll with a edited version available for download here and still cant get it to boot.
I took a picture of my system info, can anyone help me out?
