AppRadio 2 Reset Restore
By FelixEscano · May 27, 2013in AppRadio, AppRadio 2, AppRadio 3💬 5 posts👁️ 3,766 views
Posted May 27, 2013 · 20:48 UTC#1
Hi,
I recently bought an APPRadio 2 SPH-DA100 used from ebay,
When I installed into my car with all the cables for the ipod 5 it just works for the radio, when i press the Apps it says loading and stops at 50 %, when I click setting to reset to default, the OK button isn´t available so I cannot reset.
It seems that the previous owner has an Android and the radio has his configuration.
How can i reset to defaults, so I can start using the radio???
Thanks!!!
Posted May 28, 2013 · 08:16 UTC#2
Have you updated the firmware so it is compatible with an iPhone 5?
Posted May 30, 2013 · 18:48 UTC#3
I have tried but it doesnt let me
I put one file on the usb drive as the instructions says and it dont let me upgrade it.
Posted May 30, 2013 · 19:42 UTC#4
I have connected the iphone 5 directly to the phone, instead to the video adapter and it is available the apps and ipod function but it says error-02-67
Posted May 31, 2013 · 08:30 UTC#5
You need to upgrade the firmware to 8.3. Make sure your USB stick is formatted using the correct file system and try again.
