Pandora Question for Mike
By WRS · May 31, 2013in AppRadio, AppRadio 2, AppRadio 3💬 5 posts👁️ 988 views
Posted May 31, 2013 · 15:34 UTC#1
Mike
I use the EU version of the AppRadio firmware to bypass having the parking brake wire installed. However Pandora is not used in EU so it will not show on the AppRadio. Anything that can be done that you know of? Thanks for all your hard work.
Posted May 31, 2013 · 17:24 UTC#2
Mike
If you are jailbroken and using AppEx, I may be able to make it mirror if you turn on Pandora in the unsupported app list. It depends on how the app reacts to the EU firmware. Otherwise, there is nothing you can do. Pandora is basically built into the head unit so it's hard to control.
Posted May 31, 2013 · 17:30 UTC#3
I am jailbroken and using AppEX. Have it turned on in the unsupported app list but shows on phone but not on radio. Thanks
Posted May 31, 2013 · 17:32 UTC#4
I would have to update AppEx for that to work. The mirroring currently ignores supported apps. I'll see what I can do.
Posted May 31, 2013 · 19:00 UTC#5
Thanks. I know that there are others that use the EU firmware to bypass the parking brake.
