Trying to get a good background and man this thing is finicky. The manual says the display is 2400x480. So, I have tried the following:
A 2400X480 pixel image in high, middle and low qualities (hoping the unit would squeeze it into view)
A 8##X480 (16:9....I can't recall the width) pixel image in high, middle and low qualities
Same images as above but @ 479 pixel height to see if 480 is a threshold.
A much smaller image.
All alpha character file names
Earlier I had found a bunch of images on the web I wanted to try. Some worked, some didn't.
Here's the kicker about the ones that worked......if I modify them in any way, the unit no longer sees the file. Even more - if I just resave the image that already works in PS without making any changes whatsoever the unit stops seeing it lol. I tried resaving it at higher quality than the original, then lower quality and either way the unit stops seeing it
So what's the formula?
