2010 GTI - PAC Rp4-VW11 - x940bt
By Bender · Jun 05, 2013in Vehicle Specific Wiring💬 2 posts👁️ 2,725 views
Posted Jun 05, 2013 · 12:39 UTC#1
Hey guys!  First thanks for all the great info on here, made it very easy to know that this was the right unit for me.
I am wiring a x940bt to a PAC Rp4-VW11 for a 2010 GTI.  I am much more comfortable working under the hood than with the stereo so if someone could assist and verify my wiring schematic, I would greatly appreciate it.  I have been running into trouble verifying if the radio on and amp on inputs really go unused (I do NOT have anything downstream of the head unit besides a ND-TMC10 and a GEX-P20HD - no amps or anything else).
PAC Desc                           PAC Wire Color                   Pioneer Wire Color                       Pioneer Desc
Parking Break Output            Red/White                            Light Green                              Parking Brake
VSS Output                          Purple/White                               Pink                                 Car speed signal
Radio On Input                      Blue/White
ACC Output                               Red                                       Red                            Elec terminal cont by ignition
Illum Output                         Orange/White                      Orange/White                       Lighting Switch Term
Reverse Output                       Green                               Violet/White                          Reverse Gear Signal
Battery                                     Yellow                                  Yellow                                to terminal with power
Ground                                     Black                                    Black                                         Ground
Amp Turn On Input              Blue/White
Front L +                                  White                                    White                                         Front L +
Front L -                              White/Black                           White/Black                                    Front L -
Front R +                                 Grey                                      Grey                                          Front R +
Front R -                              Grey/Black                            Grey/Black                                     Front R -
Rear L +                                 Green                                    Green                                         Rear L +
Rear L -                             Green/Black                           Green/Black                                    Rear L -
Rear R +                                Purple                                     Purple                                        Rear R +
Rear R -                             Purple/Black                          Purple/Black                                    Rear R -
N/A                                            N/A                                   Blue/White                                  To antenna
Thanks again for your help!
Posted Jun 05, 2013 · 13:38 UTC#2
I have been told the antenna out, the antenna itself, and the PAC radio on wire should all be wired together.
