F900BT's buttons still greyed out despite bypass.
By torqued · Jun 12, 2013in Problems/Troubleshooting💬 2 posts👁️ 1,133 views
Posted Jun 12, 2013 · 18:51 UTC#1
Before I begin, yes I bypassed the wires in the back. Still, system settings, navigation, phone and other buttons are greyed out. I can't even check what version of software is installed. Neverthless, I loaded onto a 4GB SD card the files from the following link (http://www.pioneerelectronics.ca/POCEN/Car/GPS-Navigation/AVIC+F-Series+Firmware+Update+Download), hoping I can reinstall the entire software. Nothing. Once I turn the power on, the device never installs the files. I can't even proceed to do it manually since the button which will enable me to do so is greyed out. I'm really close to taking a Louisville Slugger to it. Thanks in advance for your help.
Posted Jun 16, 2013 · 04:39 UTC#2
sounds like the bypass is not done right...
for the record, you moved the mute wire over to the right empty pin AND you grounded the P-brake wire?
i would double or triple check everything, if the mute wire is not moved, it will tell you that you have an improper connection of the p brake wire and video will stop after a certain speed, if you P brake wire is not grounded right, then all of the options stayed grayed out and video never shows...
