If I understand the manual correctly, you can turn on the backup camera while driving. If so how do you accomplish that? I tried, but cannot figure it out. I got as far as the split screen with the map, but no picture from the camera.
The power for the camera is wired into the reverse lights, and up to the head unit to the reverse signal input wire. I am thinking the camera should be connected to permanent power, and the reverse signal input wire direct to the reverse lights circuit? That way it would automatically come on (and off) when put into (or out of) reverse, and while driving I can split screen the map. Can anyone confirm? Thanks a bunch.
