To all Professionals,
I had Pioneer mail me the SD card containing the 3.01 upgrade and when I insert it, it does absolutely nothing.
Does anyone know what to do?
Thank you in advance.
Doesn't the x930bt come with the 3.001 firmware? Mine did!
If your factory firmware is already 3.001, that's probably why it didn't do anything. Check your firmware version as described by Pioneer:
Thank you for the reply.
My version is the original 3.00 and want to upgrade to the 3.001.
Well, then I guess it should work. Make sure it's inserted all the way in (ie. you shouldn't be able to simply pull it out without pushing it back in) and turn on the ignition.
I did the same thing. I upgraded the firmware when I first got it by downloading it, but the other day I noticed that it said version 3.0000, and I had Pioneer mail me an SD card with it loaded on there. I put the SD card in and nothing. I then put in the card I had before and still nothing. I can't figure out what's going on!
