how do you get the the ground wire to stay in connector #2
ADMIN EDIT: changed title from 06/07 bypass.... ![]()
you need a crimp ( the metal piece at the end of the wire with a tooth like hook). You can buy these from many places, but you also need one of those crimping tools
I think what aznsmartass24 might be saying is that you can't just stick a wire into the hole and think it's going to make a reliable connection. Also no one has ever came up with the make/model/style of crimp terminal that is used in this connector.
You need to have a wire with a terminal crimped on to the end of it. This terminal must be specifically the mate to the hole in the connector. I don't know who makes the terminal or who makes the connector (I highly doubt it's a pioneer custom connector, or terminal).
So you can't just go out and buy a terminal to crimp on the end of the wire. At least I can't. There are thousands of different kinds in all sorts of sizes. If someone knows what type and size they are, they haven't shared that info here.
So the best thing to do is remove a wire from a different location on the connector and use it in the location you want. I talk about how to do this in my instruction page (at the bottom).
