warning screen f950bt remove?
By fiestaboyke · Jun 24, 2013in Hacks/Mods💬 8 posts👁️ 5,169 views
Posted Jun 24, 2013 · 14:00 UTC#1
Is there a hack so that the arning screen can be removed for my (EU) F950bt?
Posted Jul 20, 2013 · 16:57 UTC#2
Would like to know this as well. Did try the testmode but it doesn't work on this headunit.
Posted Jul 22, 2013 · 22:44 UTC#3
f950/x950/f50/z150/x850/f850 are all new, similar models, have a different hardware platform (now sh4 cpu - no longer arm cpu) and have a new testmode.
I dont have an x50 series hw to test on, so if we need to remove the nag screen, I will need someones help to do some detailed log collection..
Posted Jul 23, 2013 · 05:42 UTC#4
Will have a go with it later.
Posted Mar 09, 2014 · 21:01 UTC#5
I'll volunteer if you still need data from the F950DAB to remove the nagscreen etc.
Posted Apr 12, 2014 · 11:15 UTC#6
Lads, any updates on this? :)
Posted Sep 29, 2018 · 14:09 UTC#7
Hi Pianora,
You made my day...it function with the 950BT
But in SYSTEM you need to select NAND and not USER
Thanks a lot.
Posted Nov 03, 2018 · 16:52 UTC#8
Hi Hdlandscape
On 29-9-2018 at 4:09 PM, Hdlandscape said:
Hi Pianora,
Thanks a lot.
Hi Hdlandscape
You say Testmode is working. I only see a Reg file when I unpack the zip file. Can you tell us how you did it exactly on F950BT? And was it possible to update the maps? Please share your experiences.
Best regards, Kajoe
