ILL & late (07) Chrysler/Jeep connection?
By Egmont · Feb 15, 2007in General💬 8 posts👁️ 1,085 views
Posted Feb 15, 2007 · 20:18 UTC#1
I now have the ILL connected to the antenna power wire, always power. It works, but I have to manually change the day/night mode. I can't tie into the old radio harness because the dimmer/night voltage is only about 2.8 volts and is part of the CAM2 bus.
Any suggestion on another tie-in point?
Posted Feb 15, 2007 · 20:49 UTC#2
I just had a z1 installed in my 05 Jeep GC and I needed some kind of adapter to get it to work properly. May or may not be the same to you and sorry I don't know the name of the adapter. I can try to find out though.
Posted Feb 15, 2007 · 21:05 UTC#3
Thanks, It is a CAM BUS connector and the 05 is not the same as a 07
Posted Feb 15, 2007 · 21:11 UTC#4
Correction CANbus Not CAMbus. There is not ill. behind the radio so you'll have to run a wire from the parking light circuit to the radio. where exactly to pick that up, I don't know since I've yet to work on an 07 and nothing I have lists the wiring yet.
Posted Feb 15, 2007 · 22:05 UTC#5
I stand corrected :oops:
In the meantime I will live with a short cut, let us know if you find some info, thanks
Posted Feb 16, 2007 · 03:19 UTC#6
I have an 07 Envoy w/ auto and day running lights. I tried everything and finally tied the Ill lead into the rear lights. They only come on when the sensor detects dark. Works perfectly.
Posted Feb 16, 2007 · 07:11 UTC#7
In my quest for an ongoing education with this stuff, define Ill please.
Posted Feb 16, 2007 · 13:02 UTC#8
Richard, it is the ILLumination wire and it also activates the day/night mode on the map display.
