Engine noise problem fixed
By treg1 · Feb 15, 2007in Problems/Troubleshooting💬 4 posts👁️ 2,101 views
Posted Feb 15, 2007 · 21:56 UTC#1
My Avic n3 is putting allot of engine noise out of the rca outs. I know its the n3 because I put another head unit in and no noise. I was told to ground the rca's to the chassis of the head unit and that would take care of it. My question is Will a ground loop isolator do the same thing as grounding the rca's. Or will none of this work at all being the noise is coming from the head unit.
Posted Feb 16, 2007 · 13:44 UTC#2
i/ve found that ground loop isolators also impair signal quality. best option would be to find a good ground source. c
Posted Feb 17, 2007 · 03:36 UTC#3
Noise problem fixed. i tried a ground loop isolator and no change in the loud engine noise. I grounded the rca wire to the head unit and no more noise.
Posted Apr 23, 2009 · 20:25 UTC#4
I have the same problem in a N2. How do I ground rca's to radio chasis?
