Instead of rear view, what about front view camera?
By crazycaucazian86 · Feb 16, 2007in Problems/Troubleshooting💬 15 posts👁️ 3,059 views
Posted Feb 16, 2007 · 17:54 UTC#1
Is it possible to have two cameras simultaneously working? one for rear and one for front with the N3? and if not....what should i look into if i want to be able to make one? like small portable screen with a infrared camera for night time use wire it through the bumper....i mean.....what would be the best way to go about doing someting like this?
Posted Feb 16, 2007 · 18:02 UTC#2
I think this forum has officially run out of relevant questions to ask....
Posted Feb 16, 2007 · 18:58 UTC#3
You can pull the video (and audio if you want), into the AV inputs.
You'll have to select AV to see the front view camera.
Posted Feb 16, 2007 · 19:02 UTC#4
He wanted them both simultaneously, coocho.
Posted Feb 16, 2007 · 20:02 UTC#5
well basically i want the reverse camera to work like it should...but i want to be able to flip to the front camera whenever i feel like it, so from what i read with just wiring the camera up and pluggin the av inputs it should be set to go?
Posted Feb 16, 2007 · 20:38 UTC#6
I actually would like a front-view camera in my truck also, but with some sort of recording onto a small (and preferably cheap) harddrive based unit (sorta like my AVOX unit). Is there something out there where i could plug the camera into a recorder like this, and then the recorder into the AV inputs on my N3?
Posted Feb 16, 2007 · 20:59 UTC#7
we got something going here....we need the pros to speak!!!
Posted Feb 16, 2007 · 21:24 UTC#9
Wow i actually like that! I just need to find a 1ch or 2ch dvr (for front AND rear recording. watch out police! ;))
the 4 channel for $295 is a lil pricey for me right now :(
Posted Feb 16, 2007 · 21:43 UTC#10
there are a couple of single channel recorders on ebay now for more money go figure.
Posted Feb 16, 2007 · 21:51 UTC#11
Yes. Plug the front view camera into the AV inputs. Plug the rear view camera into the rear camera input. Hook up the reverse sensor lead so that it gets 12V+ when you're in reverse, and you're good to go.
Posted Feb 16, 2007 · 22:11 UTC#12
sf who do you work for? maybe i can swing by your shop and pay for some stuff to get done? PM me if ya want
Posted Feb 17, 2007 · 04:07 UTC#13
i have one camera and work both way back and front, i connect some diodo and work fine, the diodo is for have the current of 12 volt in one direction. lioke when you shift to reverse, the diodo what thats is when you shift back to go forward that way you prevent the white light to light up. you dont want that to happen, i hope you understand what i trying to explain to you my inglesh is no so good but i did and you can too. thanks
Posted Feb 17, 2007 · 04:15 UTC#14
what?
Posted Feb 17, 2007 · 04:28 UTC#15
lol, thanks sportsfan for clearing that up.
