since ford got rid of the actual VSS I opted to tap the output shaft speed sensor wire coming from the power train control module.
Now I get a low voltage read from that wire but it doesnt change very much at all as vehicle speed picks up.
will this wire work for the VSS or should I try and track down the speed sensor coming from one of the ABS units?
I am only using it because the metra axxess steering wheel control module mentions tapping the VSS.
thanks
Mike
