IPOD & D2
By AtomcC6Vette · Feb 17, 2007in Problems/Troubleshooting💬 5 posts👁️ 1,353 views
Posted Feb 17, 2007 · 14:51 UTC#1
Any ideas why i only see ipodxxx when playing music from the ipod? I never see any title information?? What is setup incorrectly?
Posted Feb 17, 2007 · 20:20 UTC#2
You might try hitting the joystick to go into the function menu. I can't remember which one, but one of them should change what appears on that line
Posted Feb 20, 2007 · 03:57 UTC#3
I looked on mine, I can't figure it out. You think Pioneer would have made it so the txt is a little bigger and you could switch to the different album or artist without having to actually switch what you're playing.. I find it best to disconnect the ipod and change songs then reconnect. Sorta what I used to do with my Alpine one.
Posted Feb 20, 2007 · 04:00 UTC#4
There is a thread on here that describes how to modify your ipod adaptor so you don't have to disconnect it. It involves cutting the blue wire inside the hideaway box of the ipod adaptor. Then you can leave it connected and still use the ipod for control
Posted Feb 23, 2007 · 19:49 UTC#5
You have to go into the menu and play around with the settings. Push the knob in while IPOD is playing there you will see the 3 options. Go into the IPOD function option not sure which is called when you hit send it changes the display to what ever you want.
