engine noise when AVIC-U250 is hooked up
By MarcL · Jul 25, 2013in Pioneer AVH Series💬 5 posts👁️ 2,678 views
Posted Jul 25, 2013 · 18:20 UTC#1
I installed an AVH-X5500BHS a few weeks ago.  Everything is working fine.  I now installed the AVIC-U250.  Once the nav module boots up, it creates a high pitched engine whine  Anyone experience this before?  I tried a new U250 and a new RGB cable, tried a new ground for the nav module, and tried in line power filters, nothing works.
Posted Aug 04, 2013 · 00:03 UTC#2
are you able to use a bypass and the u250? also can you still display video and use the u250?
Posted Sep 30, 2013 · 14:58 UTC#3
I have the same problem, any luck getting rid of the engine noise?
Posted Oct 12, 2013 · 23:15 UTC#4
check your amp HPF, i had that happen to me until i turned it off
Posted Dec 07, 2013 · 16:00 UTC#5
I use AVH-X8580BT with a AVIC-U250 and I'm having the same problem (also happens with the AVIC-F220). This noise is not coming from the installation or vehicle. This is a flaw in the RGB input of the new devices from Pioneer ("X" models).
