Z130 Map Update?
By komobu7 · Jul 26, 2013in General💬 4 posts👁️ 1,656 views
Posted Jul 26, 2013 · 14:18 UTC#1
I just picked up a Z130. I use an iPhone4 and want all the features for the two devices to communicate with each other...A2DP, Pandora etc etc. I was looking at map updates on ebay and it looks like I have to upgrade the OS so I will end up with a Avic z140BH. If I go this route, will i loose any connectivity with my iphone? What are the advantages of this update?
Also, if I try to do the hack/mod of my z130, is it possible to use a garmin map set?
Thanks for any advice
Posted Jul 26, 2013 · 17:59 UTC#2
Upgrading the 130 to a 140 which will happen with the map upgrade will eliminate your voice control for navi so if you value that feature you should avoid the upgrade.
Posted Jul 26, 2013 · 21:56 UTC#3
Thanks Vblue is it possible to back up what i have so I can revert back if I don't like the update?
Some of the updates I saw put a Tom Tom map on the unit. Is it possible to putagarmin on it?
Posted Jul 27, 2013 · 02:36 UTC#4
That deals with hacks and I am not sure of what is possible for this platform. There are threads that detail what is possible though.
