iPod music and navigation simultaneously
By Elandry · Aug 01, 2013in AppRadio, AppRadio 2, AppRadio 3💬 4 posts👁️ 1,326 views
Posted Aug 01, 2013 · 15:23 UTC#1
It seems I have gotten everything working on my AppRadio3 and my Samsung galaxy s3.
My question is, is there any way either with a modified app to be able amd play music from my ipod will using navigation from my phone either through AppRadio or Mirror link?
I would like to be able to play music from my ipod instead of my phone since that's where all my music is.
Thanks for the help.
Posted Aug 01, 2013 · 18:12 UTC#2
This will work if you connect your iPod using the 30pin cable CD-IU201N. Then you only need to double click the home key in android appradio mode and select MIX iPod.
Posted Aug 02, 2013 · 15:06 UTC#3
Thanks so much, I also have another question for you guys:I was told by pioneer that the reason Google navigation doesn't work on AppRadio mode for the galaxy s3 is because of an update that made it unusable.
Is there away to downgrade so I can use Google navigation?
Posted Aug 07, 2013 · 17:57 UTC#4
No problem, actually Google turn by turn navigation never worked. The downgrade you heard about is probably the removal of the ability to make a search text input and get basic directions.
