I purchased a SPH-DA210/XNUC from AMAZON the other day along with METRA 70-1761 harness connector and the USB/30 pin connector cable.
I am installing it in an FJ Crusier.
I have connected all of the wires, and verified that they are correct.
The parking brake lead is also connected.
When I turn the key on, the unit makes noise (Disk Drive) and the 3 buttons on the right side and the Home button light up.
After that, the unit is unresponsive, including a blank screen.
If I hook my iphone up, it will connect via the cable and bluetooth, but still no display.
I have also hooked the unit directly to the battery, using the Black(-), Yellow(+) and Red(+) wires.
The unit still responds the same as above.
I need some suggestions on what to try next.
I appreciate your help.
