Bluetooth Cuts Out/Skips
By bartonjd · Aug 06, 2013in Problems/Troubleshooting💬 11 posts👁️ 4,873 views
Posted Aug 06, 2013 · 22:29 UTC#1
I just had an Avic x850bt installed and I have noticed that every now and again while I am driving the bluetooth will cut out and come back, sometimes doing this a couple of times like a 'flickering' effect, Does anyone have any ideas of what might be causing this? I never had this issue with my AVH-X2500BT. Thanks in advance!
Posted Aug 07, 2013 · 16:50 UTC#2
My 950 does this as well. I thought it was a reception issue until I moved my iPhone 5 to the top of the unit, virtually touching it and it still exhibited the issue. It seems to do it most when streaming from Spotify at maximum quality (and yes, i have taken into account streaming quality issues, I have reproduced the problem using WiFi instead of LTE, and when I direct connect to the AVIC it does not hiccup using Spotify) but it also does it when I am playing from my iTunes library, just not as frequently.  What type of phone do you have, what app are you using, and what quality is the audio stream of the source material?
Posted Aug 11, 2013 · 03:39 UTC#3
I typically observe this issue when streaming audiobooks from the audible app from my iPhone5, it seems very random when this will occur. Any thoughts?
Posted Aug 12, 2013 · 21:49 UTC#4
I've noticed this on my newly installed 850bt. Also using an iPhone 5 to stream. I haven't tried Spotify yet to see if the same thing happens.
Posted Sep 26, 2013 · 16:22 UTC#5
Has anyone found a solution to this problem?
Posted Sep 27, 2013 · 22:59 UTC#6
Even after upgrading to iOS7, though not frequently, it still does it.
Posted Oct 10, 2013 · 18:04 UTC#7
I still experieince it on my iPhone 5s as well, very frustrating... Let me know if anyone finds a solution :) Thanks!
Posted Oct 28, 2013 · 00:36 UTC#8
Any ideas? BUMP
Posted Dec 10, 2013 · 01:37 UTC#9
I have this same problem, i use android and notice this happens with pandora as well as spotify. Any help would be appreciated,it gets pretty annoying when i'm trying to jam out.
Posted Dec 10, 2013 · 01:39 UTC#10
I have an 850bt and also have this issue,i use android and notice it frequently with pandora as well as spotify. any help is appreciated. It's annoying when i'm trying to jam the F out.
Posted Jul 13, 2014 · 20:50 UTC#11
Welcome to Bluetooth Audio streaming!  Its a problem with bluetooth.  Remember that bluetooth is a wireless signal, and although much better than others, is still prone to interference and cutting out.  I inform all my clients ahead of time that while bluetooth is nice and convenient, its not the best for quality and transfer.  There is nothing wrong with your units, just realize the limitations of a wireless signal.
Edited Jul 13, 2014 by noxguy83
