Problem with IV202NAVI and iPhone5
By Davidgalyon · Aug 11, 2013in Problems/Troubleshooting💬 3 posts👁️ 2,650 views
Posted Aug 11, 2013 · 10:44 UTC#1
Hi all,
My problem is no audio or video from my new iPhone5 thru the CD-IV202NAVI and lightning-to-VGA adapter combination. I can see the iPhone detect that an external display is attached and start sending video out, but nothing shows up on my AVIC-x940bt head unit. I have everything wired up properly (as far as I can tell)(the iPhone wouldn't detect and change modes if not(?)), switch is flipped to "2" on my VGA adapter (CD-IV202NAVI). I am starting to wonder if its defective. I had an iPhone4s and it worked perfectly, but now with the new phone and all the adapters; nothing. And yes, i was using different adapter cables back then, of course. I must be retarded and not seeing something simple and obvious, cuz it is truly a no-brainer to install and setup. Supposed to be anyway. Is there a firmware update or something I am missing? Anyone had similar trouble and able to figure it out?
Summarizing:
1. Phone: iPhone5 (which detects an external display and changes modes)
2. AVIC: X940BT (which worked perfectly with iPhone4s/cables)
3. CD-IV202NAVI (installed, 12vdc on "Acc" ignition circuit, and set to "2")
4. Apple VGA-to-lightning adapter installed
5. Lightning cable installed
6. Problem: no audio nor video from phone (iPod mode, AV Mode, etc...only audio plays via Bluetooth)
I would remove the Avic unit and ensure proper wiring but like I said, the phone detects and changes modes to send video out the lightning cable)
Posted Oct 17, 2013 · 03:39 UTC#2
Yes new firmware just released and fixed this for me
Posted Nov 01, 2013 · 03:49 UTC#3
Has anyone else installed this on their x940bt?
I tried and could not get past the screen that asked to select items with the multifunction knob.
