Can't Find Speed Sensor!!
By stathound · Feb 18, 2007in Problems/Troubleshooting💬 13 posts👁️ 1,739 views
Posted Feb 18, 2007 · 20:46 UTC#1
I did the little hack for no parking brake, however, If I could hookup the speed sensor for 3D mapping that would be great, because I find mine being a tad-bit inaccurate. I have a 98 Ford Explorer, I believe the wire is PNK/ORG Thanks for the help!
Posted Feb 19, 2007 · 00:27 UTC#2
Wowwwww, After i'm checking stuff out I goto the Vehicle Info page on the nav, My speed is being detected and its within 2mph accuracy. I have no idea how that happened! Anybody else's?
Posted Feb 19, 2007 · 01:09 UTC#3
The gyro on you bav unit is calculating your speed based on your coordinates as you move. This is normal. You get a more accurate reading if your VSS wire is hooked up.
Here is the info I found on your VSS wire:
Pos 58 of 104 Pin Connection at the PCM by the firewall
VSS Wire Color: Gray/Black
Posted Feb 19, 2007 · 01:13 UTC#4
Hmm, and I would have to remove the Dash or the Speedometer Gauges to get to this right?
Posted Feb 19, 2007 · 02:08 UTC#5
No the PCM is located under the hood on the passenger side by the firewall.
Posted Feb 19, 2007 · 02:15 UTC#6
omg, if its there for me that will be soooo easy to find, thanks so much buddy :D
Posted Feb 19, 2007 · 10:53 UTC#7
Its actually a lil hard to get to. (Maybe for me since I have big hands lol) but you cant miss it. Its a cluster with a whole mess of wires coming out of it. I have a 97 Explorer myself.
Posted Feb 19, 2007 · 19:11 UTC#8
I got to the wire just fine, however, I had a hard time figuring how I was going to run it through the firewall. Please lemme know what you did to get it into the car because I don't see any unused holes :(
Posted Feb 19, 2007 · 19:18 UTC#9
LOL I haven't. I never worked with wires and electricity ever. I never soldered anything, and am trying to work my way up to it :)
If you figure it out would you take some cash to do mine also?
Posted Feb 19, 2007 · 21:46 UTC#10
I decided not to do it, I'm gonna have the guy that does the car stereos and stuff to do it. He put in my Amp's power wire so I'm gonna have him put in this one as well. The whole electricity thing scares me especially because I never disconnect the battery lol.
Posted Feb 21, 2007 · 17:06 UTC#11
Going through the firewall in an exploder is really easy. If you look where the carpet ends by the firewall, you should see a black cable going through a rubber grommet to the left of the brake pedal. Grab a knife cut a small slit in the grommet and feed it through. You can actually fit 0 gauge wire through there with a little work. Trust me I've had to. :wink:
Posted Feb 22, 2007 · 03:00 UTC#12
Wow thats wild because, thats exactly what the guy who put the amp wire did.... hehe Thanks for the help!
Posted Feb 22, 2007 · 15:37 UTC#13
Not a problem.
