I'm thinking of buying the AppRadio 3. I'm really impressed with the JailBreak add-on work here and I just happen to have a Jailbroken iPhone 5 ready to play. This is as good as it gets. I'll miss having HD Radio but don't use it as much as I used to anyway. (can live without it)
I have a question about using more than one HDMI input HDMI input idea
I've been researching DashCam DVR's and many have no built in screen but have mini HDMI outputs.
http://forum.dashcamtalk.com/ (still researching to find the best one)
Say I wanted to view this HDMI signal on my AppRadio. I'm assuming the AppRadio only has one HDMI input, and my primary use would be with the iPhone 5.
Could I add a HDMI switch to view the DashCam when I wanted to?
Example:
HDMI 3-In 1-Out HDMI Auto Switch with 1.5 ft. Cable by HDMI http://www.amazon.com/dp/B0018DQYQ2/ref=cm_sw_r_tw_dp_JvTdsb1WS1PBH
I've used the above switch for a friends setup and it works great. It's self powered via HDMI, and auto switches to the last signal it senses turned on. (or you can press the button to cycle between)
Do you see any problems with this? "should" it work or do you know of a technical limitation that would make me not even bother trying it?
Assuming this all works, could I even use a 3rd Android HDMI cable standing by for guests? Since the HDMI switch has THREE inputs I could have #1-iPhone Lightning-HDMI, #2-DashCam DVR, #3-Android-Mini-Micro HDMI
Is this asking for too much
haha
